battery tweak after nightlies?
do you have to flash Colin's battery tweak after every new nightly? thanks!
I have never used collin's battery tweak, but my guess is yes. Since you have to flash the uncapped kernel after flashing a new nightly. Still not sure though:confused:
How do you configure Collin's? I found the directions here but I don't understand what to do when it says have "adb set up and running" How do I do that? Thanks.
you can use the terminal in your app drawer instead of this. just don't need to type in the adb, but rather the battery stats or whatever it says to type in
So all I gotta do is type everything here expect for adb?
yup..adb shell isn't needed
"Boot into recovery and flash the zip file.
After reboot, you may run batt-cfg from shell or terminal (Note, that the scripts will all request root access, so there's no longer a need to su before running them).
to run batt-cfg
go to terminal in the phone or use adb shell from your PC
once there, type
batt-cfg
It will pull up a menu of choices"
