Help battery
zubaidah
I ran out of battery on my tab. Charging doesnt help as for past day it battery charging indicator is on but only charging to 2 marks over and over. But in reality, the battery does not charge at all. I have tried to power on button but nothing works. Pls help.
You discharged it completely and might have broken the battery. Not advisable to discharge completely. Keep it on the charger for 12 hours and see what happens.
Thank you for yr feedback ..its now back in order after 2 days ..! Wonder if its time to change battery or it is normal for Samsung Tab 2 to act up like this when battery is fully discharged? Btw the tab bought about 15 months ago. Past warranty period.
You are likely to get more response if you post this in the correct forum for the Tab 2. This is the forum for the brand new Note 10.1 2014 Edition. :)
Welcome to our AndroidForums, zubaidah! :)
I've moved your thread over here to the Tab 2 area as mentioned.
Best of luck with the battery issue :thumbup:.
Cheers!
It is not the tab's fault - it is your fault. Li-ion batteries are not supposed to be discharged completely as that causes damage. Period.
But to be fair, the device is supposed to shut down before you completely discharge for precisely this reason.
I agree that you shouldn't run the device until shutdown, but it shouldn't do this if you do.
New member as of a few minutes ago can someone please direct me to the correct forum as I am having battery issues with my Samsung galaxy tab 2.7.0
Omg noone has been in here since Nov. 2013 Wow. Here goes:
Welcome to our AndroidForums, TheRealMzLovely :).
It does look like your posts are in the proper area and thread.
Hopefully, some kind member who frequents this section will respond once they hear the details of your issues--let us know and we'll try :thumbup:.
Cheers and best of luck!
