drumtrucker
noob to root: bb .4 Battery icon not changing from 'charging' when unplugged. Loaded my homescreens shifted 1 screen to left (of center), i.e. my previous center screen was 1 to left of center etc.
I would try a full wipe.noob to root: bb .4 Battery icon not changing from 'charging' when unplugged. Loaded my homescreens shifted 1 screen to left (of center), i.e. my previous center screen was 1 to left of center etc.
just confirmed battery icon issue just my being old and blind, the icon does change, is just that 'discharging' one is different than 2.1 I did do a wipe before install, using ROM manager. how do I tell if at 800?
Might have a glitchy battery reporting issue on our hands.
I am not in recovery but in CW, under advanced options in recovery you can wipe your battery stats.
Try that
I turned off my phone and let it sit for 30 minutes...battery now shows 80% in the notification bar and 70% via my battery widget. Still good battery life thus far.
Sent from my Droid using Tapatalk
