Encerspay
Something I like to do is get discoveries on Android Central and spread them here to Android Forums, not for credit, but for the sole reason of spreading awesome word. And of course I ask for OP permission before doing so.
The original thread from Android Central can be found here:
[MOD] Beats Audio for LG Optimus - Android Forums at AndroidCentral.com
Just like ilikechicken123, the OP, said, credit goes to the devs of the app.
Aaaaaaaaaaaaaaanyway.
ilikechicken123 posted this app:
https://play.google.com/store/apps/details?id=com.motioncoding.beats&hl=en
This app provides you with a zip that you flash in Recovery to give you... yes...
BEATS AUDIO ON YOUR PHONE!
Whooo! I have it on my Optimus V running BACKside IHO 0502 CM7.2.
So, as far as I know, it works on CM7. ilikechicken123 says it should work on ICS as well.
HOWEVER. THIS DOES BREAK DSP MANAGER.
BACKUP FIRST, AS ALWAYS. I'M NOT RESPONSIBLE FOR ANYTHING BAD THAT HAPPENS AT ALL.
Here's what you do:
-Download the apk from the Play Store link
-Follow directions
-INSTALL FILE 0317. NOT 0501. 0501 DOESN'T WORK ON THE OPTIMUS V AS FAR AS I KNOW.
-Make sure the file is on the root of the SD
-Get into Recovery
-Wipe Dalvik Cache
-MAKE SURE SIGNATURE VERIFICATION IS DISABLED
-Install the BeatsAudio.zip
-Reboot
-Delete DSP Manager with any Root File Manager. (Optional, but it's useless to continue to have an app that does nothing but crash)
-Uninstall the apk that gave you this zip. (Optional. It takes up lots of memory and is basically useless after the flash is zipped.
-Enjoy Beats Audio!!
Again, give the credit to the devs of this app for this. Thanks to ilikechicken123 for posting this really useful app.
Now it's time for Mozart to blare on the speakers.
Here's what you do:
-Follow directions
-Get into Recovery
-Wipe Dalvik Cache
-Reboot
