Help Beautiful widgets and launcher pro
kstuffer
Member
I just downloaded beautiful widgets and love it.the only problem is that the normal size home widget is messed up when I use launcher pros five row setting. Anyone know a fix got this
I'm pretty sure there will not be a fix unless LP guy releases it. It states under that option that it looks bad, so best bet is to switch back to having four.
having it set to 5 rows causes the background of the full size beautiful home widget to skew and not fit completely around the widget.
