If you want to root your Droid Incredible 2 right away you had better not take the current software update. (32mb 2.3.4 one) Watch out, when I activated mine and setup my google account my phone automatically connected to wifi and started downloading the update like less than ten minutes out of the box.
I might be wrong but I think root is not available at this time for the 2.3.4 update, I saw some thing about people not being able to get S-off because of a certain number build of Hboot is locked.
I am sure the dev community will find a way, it will just take a little while.
Anyway, you can definitely root 2.3.3 dinc2, check out the dinc2 all things root section, it is a sticky.
After you root you can flash,change &run custom ROMs that look cool and have upgraded software versions and higher versions of hTC sense.
Like the are some roms with 2.3.5 and sense 3.5.
And of you get tired of a ROM you can just flash it and switch and try another one, so you are never stuck on a certain software version or ROM, at least that is my general understanding of it.
I can't wait to root mine and play with the roms. trying to decide between CM7, Syndicate Rom, Virtuous Unity, and GingerBang. haha
Try newtoroot's HD ROM. It's in one All Things Root forum. It has Sense 3.5, governor so you can overclock, etc. It's nice!
Flirting with the lady on the phone I guess lol
But they sent me the wrong phone today![]()
Lol drew
What's titanium?
Hi,I root for unlimited customization, better battery life, faster performance. All good things. Also, afaik, you can return it to non root if you need to.
