Any suggestions on the best Barcode Scanner for Desire?
im using ShopSavvy's Barcode Scanner, i like it![]()
I use this one also. Excellent.Barcode Scanner by ZXing team is a good one
sadly shopsavvy might not work in your area so if it dose not you might wana use Barcode Scanner by ZXing I find it a lot more simple and efficient to use.
I'm not sure how you can get much simpler than Shopsavvy. You open the app, tap the top menu button, and point the camera at the barcode.![]()
Then you obviously haven't tried the other one.
You open the app. The camera automaticly gets started, and you'll see a rectangular with a red little bar in it. Point at the barcode, and you're done.
...Which is all of one button push less than Shopsavvy. Everything else is exactly the same, you just need to tap a button to activate the scanner. But it allows you to scan product barcodes and do price comparisons as well. I'm not seeing why the other one is better here?![]()
Interesting to see you monitoring the forum! Since you're here, one nag I do have is that for some things when you scan them you get results, but for a totally different product. I'm assuming this is the manufacturers fault for not using unique barcodes? If more than one result is in the database for that barcode, will the software prompt you and show both?
Is shop savvy and barcode scanner different apps
Yes, but Shopsavvy has a barcode scanner built into it.
hello guys, profoundly i would like to raise attention regarding Shop savvy barcode scanner technology that intrinsically helpful and productive enable functionality with its impressive readable quality technique inbuilt with Android APP.......im using ShopSavvy's Barcode Scanner, i like it![]()
