aredflyingbird
hello, whats the best rom and kernel to save the most battery life?
Download data enabler. It will save more battery than any ROM or kernel. I found any b version to be hard on battery. If your not on d version flash the stock version of whatever your on. Upgrade root and backup. Make a copy of backup outside of phone. Remember to disable data when not using it.
With that being said, 2xbattery IS pretty dank.)
if ur on zvb u could use ldk ick 1.4 with homeless kernel 1.3 u will save lots of battery i was getting about 15 to 20 hrs with heavy use also extended battery
data enabler is not good i recommend 2xbattery u can set up automatically to turn date off when phone goes off
data
They could help more if they knew what SW MS910ZV b or c or d your on just saying
Juice defender
best anything for battery would be a good kernel and a safe userThis is the one thing I save the most juice with. I bought the ultimate and it is amazing to say the least. Cuts off data when the screen is off and cuts it on instantly when i unlock the phone. As well as a million other features I can use to further save batter.
Get this app, dont overclock and you are good.
best anything for battery would be a good kernel and a safe user :d
best anything for battery would be a good kernel and a safe user![]()
I use "Go launcher EX" and they have "Go switch" and "Go power master"
Using both of those my battery can last up to 30 hours with standard use. Means texting all day, moderate use of 4G, a couple hours of google music, normal call use, a game or two.
These programs allow you to choose a setting or make a custom one that lower your screen brightness, turn off 4G until you need it, turn off running programs with one tap and many other things.
Mine says 34 hours left right now when it is fully charged. I always get back home from work (8-10 hours) with 35-70% battery depending on my use. I always get at least 18 hours battery even if I use it a lot and more than my standard use.
I have tried all the other battery savers, these 2 are the best when you combine them.
The switch lets you manually turn on/off 4G, wifi, adjust brightness, screen timeout, bluetooth, etc. the widget has all of this with 1 click and many more.
The power master lets you one click turn off running programs, also lets you set a mode, each mode will automatically turn off different things or lower things to save battery. It also shows you how much battery time you have left and shows what is using the most battery as far as hardware and software and other useful info.
With this setup I feel like I have 3 batteries now and never even bring my charger with me anymore(was a must when I never used this).
take your battery out it'll probly never die lol... but yeah of coarse there many more ways to save more battery.. there's alwayyyys more ways...Once you already have both of those think of how much MORE battery you can save.![]()
