Help Best case? Best car charger?
BwB661
Just got the phone yesterday. Any good cases you guys can recommend? Hopefully the case doesnt wear the gray color off the sides. Also is Verizon's car charger good or is there a better one out there?
Thanks for the help
Depending on your needs casewise there is definetly alot of options. Cruzer-Lite, Diztronic Revision 3 are both good cases for value and mid-level protection. If your hard on your phone id recommend otterbox defender, its bulky but provides best protection I know of. Check the link below regarding cases, lots of pics and info on the topic.
http://androidforums.com/samsung-galaxy-nexus/463598-cases.html
As far as protecting the phone from wearing you could look at a skin, ghost armor comes to mind. But be carefull as certain cases will also pull these skins off.
I believe any microusb car charger will work fine, as long as its
1A of power. (Someone can correct me if im wrong).
For a charger I recommend the Rocketfish Premium charger from BestBuy. It is pretty spendy (~$26), but it is worth it. Fastest car charger I have ever used and it also has an additional USB port to charge a second device.
