inkmachine
Hi,
I've been using the FreshROM for a while now....probably since April or May I think. It seems that the developer is slowly moving away from doing anything else for the Hero version of this Rom and is focusing more on the EVO.
I was wondering if anyone could recommend the best possible ROM replacement for Fresh?
I think one major requirement is that the Apps2SD be standard included in the ROM so that it wouldn't have to be installed separately.
I know ROM choice is more of personal taste, but I'm curious if any of you know the more recent 'hot' ROMs out there or the most used STABLE ones and updated frequently.
Thanks!
Jason
Thanks!
Jason
