Timaphillips
I just installed Cyanogen from DroidMod and while I was at it, I installed the p3 1ghz low voltage kernel. So far, I'm pretty happy. I'm not sure it's been a huuuge battery saver, but I think it's helped. Wifi and bluetooth have been on all day. A few phone calls. Lots of texting and emails. Also some market apps downloaded as well as files transferred on/off. At 8:30 my battery life is at 50%, which is pretty damn good considering how much better that is from strait out of the box on release day.
I'm running 800mhz overclocked, instead of 1ghz to save some power. Should I switch to a different kernel since I'm not even using the 1 ghz slot?
What's the best low voltage kernel for battery life, overclocking included? No need to even bring up stock speeds...
