ok hi members but this is all a little confusing for me but can one of you guys post the link to a good 16 micro sd card good for the motorola triuph for me from radio shack or best buy that i canpick up in store thanks
Thats the same thing I have Mantyeera on Amazon its 30 dollars.
You are better off with this one by ADATA. Not only is it a better quality brand but it's cheaper. Class speed doesn't matter when it comes to phones.
ADATA 16GB MicroSDHC Card (Class 4) with adapter,AUSDH16GCL4-RA1
I confirm that a test shot around the room looks somewhat smoother from the one I had leftover on my other card.Has anyone confirmed that going to a class 10 from a class 4 improves the "Skippy" video while panning? My friends Iphone takes much smoother video and was wondering if going to the class 10 will actually improve the Triumphs video so it is "smoother" when panning.
Bob
I've seen some 32gb cards on ebay for around $20, question is will they really work?
Just got my Adata 32GB class 10 card today. Formatted using the phone and copied files from old 4GB card to it using PC and it is working quite well. Video now is noticeably much smoother.
Bob
I have the included 2GB card now and want to upgrade to a larger SD. What's the process of getting all of my apps and such transferred over to the new SD card? Is it as easy as what we normally do for our cameras, computers? Just copy>paste?
Or do we have to do formatting/backing up whats on the original card in someway?
I am not recommending but I just want to report that I am using no name brand class 4 16g from microcenter and all is well.
They are $16.99 now but I am sure it will get lower. There was black Friday special for $12.99 couple of weeks ago.
The general rule of thumb is that the class of the SD card ONLY affects things that will ever use that speed.
the most read/write intensive thing you can do off the SD card in the Triumph is playing and recording HD video. 720p is what the triumph can do, and a class 4 or class 6 card will suffice.
nothing else the phone does will take advantage of that speed and those things would work just as well on a class 2 card.
if the triumph had 1080p, maybe a class 6 would be the minimum card of choice, but its only 720 so we dont have to worry about that.
I use a HP branded class 6 16gb card, but im upgrading to a 32 in a few days becuase the 16 is getting really cramped
And to a class 2 card is painfully slow which I have unfortunately experienced before LOL!While you won't notice a performance difference between class 4 and class 10, the class of SD card you have makes a huge difference when transferring large amounts of data to it.. like from a pc for example.
Copying 16 gigs of data from a pc to a class 10 card is lightning fastAnd to a class 2 card is painfully slow which I have unfortunately experienced before LOL!
How many users (not the heavy file swappers like me) really transfer large amounts of data at a time often enough for that to matter?
the majority of users will transfer between 4 and 8 GBs of music, maybe another 2 or 3 of movies or videos, and that content will sit on the card for months before being refreshed.
in daily use, the card speed doesnt matter so much.
but, of course, I use my cards to transfer big files between work and home and stuff so I benefit from it, but my point was that most dont see that single benefit to a class 10 over a lesser.
I just got a 16GB Samsung Class 10 from Amazon for $27 delivered.
I copied the 2 GB data to the new card, using a card reader, and installed it with no problems.
I decided to get a name brand and a class 10 based on advice from this thread. Some times it's not wise to save pennies.
