best notepad app for evo
we all know that the evo didnt come with a native notepad app unfortunately especially for people who use there phones for music writing and such when on the go but the android market has damn near everything and i came across ak notepad which is a good app but more then one time the shit deleted a couple tracks......and im done with it any other good notepad apps out there well im looking for the best one to write music on something good like the memo pad in the blackberry or iphone
I also use color note. It has regular notes and checklists. I use it mostly for shopping lists, so no comment on how it would be for music writing. It has never deleted a note or list i made that I have noticed..
i also use color note. Simple and effective.
If you want something more advanced check out Evernote! :D
I use Evernote. They are backed up online. Or you can try Catch. I have both installed but, I recommend Evernote.
AK notepad works great because of the export feature, but for quick little jots, I use the HTC Tasks widget (limit 50 chars), which also makes me happy.
Been using AK for a while. It's simple to use and has a cloud backup feature. I love Evernote on the desktop but the app was a little weak. Got to give it another try!
I've been using InkPad, but I'm gong to try Color Note. InkPad is ok, but not very inspired. More of a nuts-and-bolts, basic information keeper.
Started using Catch Notes today and I really like it much more than evernote. One thing I really like is that you can pin a note to the home screen just like AK. Hopefully their widget won't dissappear like evernotes always did.
I used AK Notepad until it erased all my data after an update. I like it, but don't want a repeat of that. Now I use UltraNotes.
I use CATCH.
Its got a great widget, SD card backup, password protected, and lets you take notes with pics from your gallery, or snapshot on the spot.
Here is the link:
Catch Notes
by Catch.com
>250,000 downloads, 12377 ratings (4.3 avg)
Free
