Root Best Rom for emulators
silvers46
just wanted to get some opinions on what roms and kernels work best for n64oid and fpse i play both those alot so battery life im not to concerned about though 10 hours off and on play would be nice the only requirement i have is that i can use the ps3 controller bluetooth app with it last time i checked sense didnt have the right bluetooth stack or something like that thanks for any help in advance
you are correct the only one that has it is cm7 that can support the particular bt needed to control controllers like the ps3 or the wii remote. as far as emulators go to play rom games, it will really not matter too much on what rom or kernel you have.
check this out though:
DIY EVO-Tainment gaming system built around HTC EVO, plans for mass production in the works
