Just to give you some other feedback. I am currently on Radiactive Froyo 1.8.6 and using launcher pro plus. It all really works well together and battery life is equal if not slightly better than Ultimate Dream 3.0 was. Not sure but I will try this for a little longer and I may not try Titanum X if this continues to run smoothly. What did you decide on cold?
Question...I am running mightydream 1.0...anyone have any issues changing your apps to be stored to sd card? I would like to do it to help speed things up.
How does the interceptor ROM compare "head to head" with Radioactive FroYo (1.8.7)?
I've been pretty happy with 1.8.7, but I'm still having mediocre GPS performance and occasional CDMA lockups.
Does the interceptor ROM still have issues with CDMA lockup (I assume it does)?
How about WiFi tethering? Is that included in the ROM out of the box like it is with Radioactive FroYo, or will it have to be added in manually?
-SF
Hoping this thread isn't dead; 'cause I don't want to start a *new* one...
I have tried several of noobnl's Radioactive FroYo's (double-digit revisions up to 19) ...and had *nothing* but problems...random reboots, flickering screens, slow task-switching...garbage. I've had similar issues with Titanium X.
Seems the last one that worked decently was joeykrim's DE03, but I was hoping to get in on this JIT thing that everyone's raving about.
(Ohh, and I have a Moment, BTW.)
Any suggestions? (preferably with Links?)
Thanks in advance!
Thanks in advance!
Thanks in advance!
I too am researching the FroYo roms to potentially update to a better version of Android. The battery on the stock 2.1 is killing me. Anyone have recommendations on the most stable combinations of Kernel & ROM that is the most stable, best battery life, which websites did they find them at, and what software is needed? Any responses would be appreciated.
I have rooted Samsung moment with latest froyo like version 22 or something, and quite happy with it using the instruction below. It worked.
samsungmomentforum.com/samsung-moment-how-to/rooting-for-dummies/?PHPSESSID=0e53850df6245d28c9b1a257fcc16728
I want to use the custom ROM kitchen to get the theme looks like evo4g, and if anyone can tell me if I can do that without damaging my froyo custom rom?
Stability and Batter life are MUST, and I wonder if someone can list of the items from Custom SDX ROM Builder site which has worked for them to give better battery life and stability, and some speed, but not bleeding edge speed at the cost to stability.
first of all.. there is NO true 2.2 rom. there are 2.1 that run with JIT compiler but no TRUE 2.2 as far as the kitchen, you can put anythign you want into it. once you load that custom it will take over your current rom with as many options you told it to. it is advised taht you flash back to origional root before overlaying kitchen roms over any other custom or vice versa.
i am running Amstel 2.0 which is basically radioactive froyo running over meatkernal. this is VERY stable and has given me decent battery.
one of the biggest killers of battery i have found is IM clients like Meebo (or even stock IM client) with that off i get over 24 hours. with IM signed in it cuts it in half (12 hr max life)
