I know this changes quickly.
Been running Virtuous for a long time and just ran into a boot loop and wiped the phone.
Looking for the best ROM out there.
Anyone got suggestions? Looking for something Stable.
Open to Sense or stock.
ROMs are really a personal preference. I've had the best experiences with Re-Engineered 2.3. It's fast, stable and highly customizable. CM7 is really nice as well. The battery isn't as good as sense yet, but I'm sure it'll keep getting better. If you're a flashaholic, you have to at least try CM7. Warm 2.2 is a damn fine ROM as well. It doesn't get a lot of love lately, but it's stable and fast and very nice. It was the first custom ROM I flashed on my Inc and I stuck with it for a long time. If you haven't tried it it's a good option. I've never flashed any Z ROMs (need stability, phantom calls and others issues don't work for me at all) so no opinion on any of them. IR 2.3 is my daily driver right now and it'll take a lot for me to switch from it because it's that good.
I'm abandoning Virtuous because the developer is MIA - doesn't update anything or AT LEAST keep us up to date.
Is everyone recommending CM7 or Skyraider?
So is it CM7 for speed and Skyraider for battery life?
How is gingerbread working for everyone?
Thanks everyone for your feedback.
I tried CM6 (because it was in Rom Manager) and I like it. Got it setup how I like it but now am intrigued to try CM7.
Can I upgrade to CM7 without a wipe? Will I loose much of my settings?
How do the nightlies work?
Do all of the ROMS require a full wipe? If not then what are the best of the ones that don't require it?
In order for the new ROM to function properly, you need to wipe. Always backup after you get it the way you want it, then you can just switch between the ROMs.
I like the Sense, so I stick with Sense mods. Right now I'm using the setup below from my siggy in another forum, and love it.
New to android or just need to brush up on the basics? Abe has every thing you need Here:
Droid Incredible 2.2 Rooted
ROM: Redemption Rom 2.3
Kernel Version #9
No problems with the ROM, but I am having problems with ROM Manager since they updated it to 3.0. I can no longer install/backup/or doing anything while running the app. I'm hoping they fix it soon. Any alternative ROM Managers would be helpful.
