I want your guys's opinion on the best I MEAN BEST rom's for optimus M![]()
By most/best features or functionality?
Id say features.
BACKside (everything works)
MIUI (MMS is broken but can be fixed)
Make sure you use CWM and not GNM, mms doesn't work with GNM recovery at all on both of these ROMs
U should be able to find it now in all things root
IDK about you, but MMS does work for me on Backside having used GNM recovery. All it takes for me to fix MMS is reset the username and password under the metropcs APN entry.
Others have told me Mms doesn't work and they had GNM and they switched to CWM and it worked fine....
Well I did just install BACKside last night so we'll see if it develops any problems in the future as some have mentioned data stopped working after a while. For now, pictures seem to upload and download very quickly for MMS. Surprisingly quicker than BobzHome ROM
Also I'm on bobzhomes newest cm7 and I'm getting FCs by every app after a while and I have to reboot for everything to work right....
Yes I got the latest version you posted on the thread v0.7. And yes, Bobz Rom seems pretty faulty. The best version of that ROM was the one released on 11-13-11. The ones after that were faulty on my phone even after a few wipes.
