What are the best Sense based ROMs out there....One that allows apps to be put on SD card??
is Zen 2.1 or 2.2 based? I think im gonna give it a shot for hoots
is cm6 still the only 2.2 based rom for the cdma hero at this point?
Thanks for the info.....I went with nfx hero.....should I be using a task killer? Ot are they designed not to? Also, what is jit?
How do you enable or disable JIT?
I am using NFXHero2.2.
I noticed nfx hero 2.2 has an update. How do I get the update without losing everything on my phone??
I don't think it necessarily an update for NFX. This [ROM] NFX Sprint 2.31.651.7 STOCK Deoxed/Odex Updated:9/27/2010 - xda-developers is based off of the recent Sprint update that they put out. If you are going to try, nandroid, wipe everything: data, Davlik cache and cache, then flash the rom
did zen every fix the gmail notifications problem? any other problems it has. i clicked on the given link but it would seem to indicated their are no more quirks, bugs, etc. which seems... implausible.
Okay, this may be a dumb question but here goes. I know how to wipe the data and the Davlik cache but where and how do you wipe the cache?
[ROM] NFX-Hero 2.2.1.update1, 9/5/2010 Friendstream+Deodexed/ODEX+JIT & more - xda-developers
Yea Gmail works great on my ZenRoms
interesting. so u are running zen now? and it is sense based correct? i'm going to update today, and am just deciding between zen and nfx. any quirks or caveats w/ zen i should be aware of?Zenrom and ZenEXP are both alot quicker than NFXhero, and the gmail issues they used to have have been fixed for awhile now.
