I tried using the GV Dialer and found that it always calls out with the GV #. There are times I like to call with my real number and found no way to toggle this on and off. Unless there was something I didn't see/find. Other than that it looks good JB, very informative.
Not necessarily. You can add a shortcut to your home screen that allows you to toggle google voice between 4 modes: always call using GV, never call using GV, only international calls with GV, or prompt every time.
He is talking about the third party app GV Dialer. The dev needs to make a widget.
Has anyone had issues with the outgoing GV # changing that would require continual reconfiguration of the 10 Friends of Family #'s?
AND... are the 10 FF numbers able to be changed at will? (To remove the old outgoing GV number and add the new)
I only use google voice for voicemail. I set up conditional call forwarding, it forwards all calls to my gv number instead of going to voicemail. They leave a message with gv, and I basically get free visual voicemail.
Same here, I can't believe I used to call a number and navigate a menu to check my voicemail!
How do you set up Google voice mail on your phone? I have the app and have an account but I cant figure out how to set up the voice mail, when it get to the provisioning code part it has me call a number but then I get a Verizon wireless error when I connect to that number
Any advice on configuring google voice for free sms?
any way to integrate with handcent?
