Root [Beta][ROM]~*UB-A75-2*~
ninadchaudhari
What's up !
Presenting UB-A75-2 for MICROMAX A75​
deveoped by Ninad (aka, ninadchaudhari)​
Special Thanks to
GTA -- For the Gr8 Find < -- really great-full ,
Rudra Teja -- For first finding the base chinese ROM
:p​
Current Status :
V3 Uploaded ...
Still in beta , [ New-bies stay away :) ]
New Features :
  1. Over-clocked to 800Mhz ( Use SetCpu ,it will note the Max freq . )
    Guys ,
    Its Over-clocked ... you are going to get a bit of Low Battery life ...
    its called the use of common sense ....
    I have made changes to add battery as much as possible .... but hey !
    ur processor does not support change of Governor ...
    and/or Frequencies ...
  2. Amazing new Boot-animation and Boot sound
    you guys gonna love it ! I can bet on it :)
    Nexus Animation (ICS)+ Custom Sound !
  3. Better compiled than Mmx one
  4. Great Framework !
  5. Based on Gionee ROM ,
  6. Edited Scatter file for 2Mb storage :D
  7. Indian and US APNs added
  8. File manager not removed on a very popular request :D
  9. Kept the Gionee Launcher + gingerbread also added .
  10. Google services added like , sync etc ..
  11. Google Play shop added
  12. There (Gionee's) proprietary store removed :p
Awesome Features From UB-A75-1:
[ Also included in UB-A75-2 ]
  1. Rooted
  2. Most Bugs fixed , no need for any program execution
  3. Shell scripts support added
  4. Full bash
  5. 'sysrw' , 'sysro' , 'many scripts 'added
  6. de-odexed all the apks --->I was strictly against it as it increases the boot timings but many devs convinced me
  7. This ROM is compatible with All the future offerings !
  8. Gtalk with Video/Voice calling added
  9. Ice Cream Sandwich Animations added
  10. Gingerbread fonts replaced by Ice Cream Sandwich fonts
  11. Ice Cream Sandwich Keyboard added
  12. Scroll Glow added
  13. MIUI Music App
  14. Battery icon changed to more informative thing !
  15. over scroll color changed
  16. S99 Supercharger script Note : Activated after you install BusyBox ...
    i have done the balanced 1 configuration of Supercharger !
    If you guys need anything , Just use the script to activate :)
    No need of any script manager ! .
    a script in data/99SuperCharger.sh .. runs at start ( I have configured so !! ) so even if u change it works ;)
  17. Host files added -- NOW NO ADS IN ANY APP U USE :p
  18. Build.prop tweaks for better battery and performance added
  19. NO BUSYBOX added , i cannot install it by default,caz the way i am making the ROM is difficult
  20. Build.prop tweaks for
    • Force launcher into memory
    • Render UI through GPU instead of CPU
    • Time between wifi scans is set to 300 sec
    • Allow power collapse tweak
    • Cpu is set to sleep when not used ! but registry values preserved
      New*
    • Few Tweaks to bring the Stock MMx experience than Gionee one .
If u feel i need to make changes ( if any ) in credits and/or any other stuff , plz PM me :)
Installation :
Download :
  1. Flash the Files as usual
  2. Manually install Busybox
Just 125 Mb Download ...
Includes All files and Flash tool .
Link : UB-A75-2_v3
Note : this is in Beta still ...
Guys, Guess what ,
I have already Planned about UB-A75-3 :)
Uploading ...
Sorry for the night stuff :)
I uploaded the entire stuff then suddenly a idea clicked me at 3:00 AM :p
i know that's weird :D
Hence re made the ROM :o
Now uploading !
But i will paste the link when i wake up ( sleeping at 7 ) :)
Hi Ninad, thanks for your hard work, you're awesome..!
I have a questions about the Beta Rom UB A75-2 :
1. is it possible to install market or gmail, because previously I have try using gionee gn105 rom, the market not included in default rom and when I try to install it the market (google play) is not working?
2. How can I know that the processor is 800 mhz after flashing using your UB A75-2 rom? is it using any apps such as antutu maybe, or how?
3. where is the download links for this UB A75-2 rom?, I can't find it.
Wow ! u guys are really quick :D :D
I just posted the thread and 3 replies ?? :p
btw, for the download link and other stuff plz refer to the post :) ,,
Uploading ...
i know that's weird
Now uploading !
Really sorry but cannot help it :)
I was awake the entire night :p
Thanks for reminding me abt the Play shop app !
its included btw .
For the 800 thing use setcpu
I have flashed it Successfully :)
Flash tool that you provided in package is not working. We can only flash this device using SP_Flash_Tool_exe_v2.1121.01.
Boot animation looks awesome :D . it took some long time for the first boot as you said.
After booting, first screen i saw is google backup and restore. when i hit finish it showed me some force close error. "the application google partner setup (process com.google.android.partnersetup) has stopped unexpectedly. please try again."
except this every thing went fine.
Please remove eweather, ebackup (both are in chinese) and another china app (watch it in screenshot). I have uninstalled them using Titanium Backup. :D
playstore is not included. I installed it manually and logged in successfully :)
Homepage of Browser is in chinese (not the matter ;) as we can change it )
Notification bar is looking great :) But fonts of toolkit is not visible. (which is in white)
@Rudra Teja ,
Amazing job Mate ;)
The Amazing and quick report :) ... really appreciate !!
Just give me a few minutes ! correcting it now :)
one more thing ,
What abt. the internal memory ?
how is it more used :confused:
Can anyone tell how to use set cpu in a75..pls
set cpu not working.,also voice search not working..how to fix that?
ROM updated ...
If still problems Prevalent let me know ...
I have included the SP flash tool !! thanks Rudra for letting me know that only this works on A75 :D
Check the same site !
Uploading now :p
My class at 6:30 to 7:30 hence will update the link later when i come :)
Guys,
Updated ...
Just remember , this is beta ...
even if this works I am going to upload it once again
I am going to make a small change if this works :)
Which will undoubtedly work up :)
Those of you who have Limited bandwidth ,
Not familiar to anything ,
Requested stay Away .
Ninad i backed up all user apps+system data using titanium backup ,
i can restore after updating (ub-a75-2) i can work are not , many application on sd card its require format and restore are not please tell me
when will u going to upload the final one??
i am dying to download that...
Is this rom going to change the notification panel that was in a75 before??
Hi ninad, I have try the UB-A75-2 beta, here is my experience problem right after flashing :
1. there.s an error message when the phone just turn on or even reboot "the application google Partner Setup(process com.google.android.partnersetup) has stopped unexpectedly, please try again.
2. it can not add google account, it always 'can't establish a reliable data connection to the server'. I have check the internet connection using browser is works fine.
3. The Ice Cream Sandwich keyboard also is not working, its always error.
PLEASE CHANGE THE THEME..
keep the original android theme..then the phone will b more faster...
and remove unwanted application...
