Danielson2047
Does that make any sense? I have the lte gnex, and notice noticeably worse batt life on 3g. Thoughts?
Has to be signal strength related. You have a strong 4G signal, but extremely marginal 3G signal most likely. Only explanation I can think of.
Unless you have horrific 3G reception where the signal goes in and out, that should not be the case. 4G uses substantially more power than 3G.
Really getting irritated with this thing, sitting at work for 7 hours, wifi on, only 20 min screen on time, down to 56%. grrrrrrrr.
You need to figure out what is draining your battery. Its likely a service syncing in the background or an app pulling background data. Google+, Facebook, and photo sync are known to be big background data hogs.
