On Better Keyboard, if you go to Settings>Keyboards & Layouts and scroll all the way down to the bottom, there is an option that says "Smiley Key" but it is faded and unclickable. How do I fix this, or get this Smiley Key option?
Trying out a bunch of new keyboards huh . I cannot help you on this one as better is not one of the half dozen keyboards I have. If you are looking for a keyboard will multiple smileys built into it give Swiftkey a drive
Nothing fancy but it gives you 3-5 one touch smiley's
