jdLordHelmet
My primary issue is being unable to mount /system RW, but i think the problem is bigger than that. Here is what happened.
I started with Android 4.0.4. I used Odin to put CWM recovery on my phone, and immediately made a nandroid backup. I then installed superuser through CWM. Rebooted. Root worked fine. I installed titanium backup, and was able to use root explorer to rename files in /system (just done sound files).
I decided to try CM 10. Installed it through CWM, got a boot loop. Apparently it didn't like the external sd, but i don't know. I had to use another recovery program (starts with a T, don't remember the name, it was touch screen). Got CM installed, didn't like it, decided to revert to my nandroid backup. So I reinstalled CWM through odin, wiped/factory reset, recovered from my backup.
Now, things seem weird. The phone seems to boot slower. "power off" leaves me at the goodbye screen unless i hold the power button, which sometimes makes it restart again. I cannot mount/system as rw, even though i appear to be rooted still. I have searched and tried many different things, but i feel overwhelmed with the possibilities.
The main thing i want is to be able to mount /system RW, like i could when i first rooted.
