HolyGrail
The forced Bing is starting to seem like a real issue. I have a Dinc but would really like the bigger display. Started using Bing to see what its like and its not all that good. Pretty bad interface too. Kind of hard to read.
Would going with a 3rd party browser fix any of this (besides the soft key issue)? I mean can you dedicate the search from the browser to Google??
You can set Google as a bookmark, or go to Google.com and type in there. If you use the voice search tho, it will just show Bing results.
Do a search for, lets say "How big is the sun?" in Bing, then search the same on Google, and compare. Check images also on the same comparison. You will see the difference. Bing is just terrible.
