How the hell do I take this thing off? Anyone?
I'm trying to put my old memory card in from my DX that has all my pics saved on it.
I feel like a noob, but I don't want to break my phone that is only 4 hours old.
There's a notch right below the power button. Use that to pull it off.
Thanks, I saw that but it wasn't really coming off too easy.. so just pull it off? It doesn't slide down or anything like the DroidX ?
I have found that after pulling the corner with the notch of it's easiest to work your way down the same side of the phone as the notch. Once that side is off it just comes right off.
If you try pulling that corner and then moving across the top and then down the opposite side it is much harder and feels like it could break.
Also "that's what she said"... hope it isn't that easy all the time on mine!
