When I answer a call on my nexus 4 the screen goes black. So cannot end the call or view who is calling. Having to switch the phone off to stop it. Any ideas folks as its very frustrating.
Does this happen before or after you have put the phone to your face? In other words, is the proximity sensor a suspect?
i had the same problem, it is because there is a sensor on the top left corner if u notice, if u pull the phone down like u are on speaker phone so that nothin is close to the sensor the screen will pop back on, i thought my phone was messed up too haha. but its actually just a cool battery saving feature
Thanks. But cool feature or not how do I end a call? lol![]()
What happens when you hit the power button when you finish the call? This should switch the screen on.
Pressing the on and off button shows the screen very faint But it goes again
Then seems to reconsider and the screen comes on
But dont want to be hanging on
Where is the sensor then?
All new to me Had a HTC before
Only prob with that was sometimes it would not let me drag the screen down to answer
Now I can answer but not stop lol
There is an option to end calls with power button in accessibility settings.
Where is that? Is that a good idea then?
I found this but still having problems
http://forum.xda-developers.com/showthread.php?t=2001861
You never said whether you had a screen protector, which seems to be the common source of this problem in the XDA thread. Basically, it comes down to this, in my mind at least. If the proximity sensor (essentially a light sensitive sensor) isn't being occluded, you have a defective unit and should return it for warranty repair. Work arounds are going to get old really fast.![]()
I have a similar problem, there is definitely something weird with this phone and how the proximity sensor works compared to all of my past phones, I have not found a pattern because I tend to try to ignore these things because they frustrate me. I do not have a screen protector.
I have the same problem with the screen off after a call and no ability to hang up.Where is that? Is that a good idea then?
