Help Blackberry calendar to android?
jeffbet
Just got my Epic last night.
Using blackberry curve and built in calendar. Not synched anywhere else.
What is best way to move my calendar appointments to my droid?
I do have a mac with entourage on it and a windows machine with outlook.
Recommendations?
Thanks.
I don't know Blackberry. But from the Android end, your calendar will be your Google calendar for the Google login tied to the phone.
The easiest way to import to the Google calendar is on the Google Calendar website using a browser on your computer. You will need a file in either the common iCal format or the CSV format that MS Outlook exports. Is there a way to export your Blackberry calendar as an iCal file?
I believe you should be able to sync your blackberry calendar with a Google Gmail one. Then the android phone will sync automatically with that gmail account...
Just go to http://m.google.com/sync on your Blackberry browser...
