Help Blacklisting no longer working
pookieguy
Hey all,
Everything was fine up until yesterday. The blacklist number feature no longer works. I've tried many things but it still doesn't work. Yes, it does actually add it to the blacklist but the number still filters through now and rings.
Any ideas?
I have used other third-party software for this that works fine but I would like to just use the built-in feature if possible.
Thanks,
Mine works at times...doesn't work others.
Sometimes rings once
No idea how to fix it. it was no different on my other android
Mr. Ed,
Yeah, I haven't figured it out either. Very strange. You are right, it works sometimes though.
I might just go back to Mr. Number, which is great! I just wanted to see if something simple like this will do. Mr. Number, both their website and their app are excellent with plenty of options.
--mike
