CrimsonToker
Android Expert
Are hangouts and lumen toolbar safe to remove?
What about the play crap? Play books, games, music, movies/television, and newsstand are all worthless to me. And can anyone explain what Qualcomm izat is? Also safe to uninstall?
You're a tad off on this... You just described the connections optimizer. Lzat enhances location accuracy over mobile networks and Wi-Fi.the qualcomm izat in my opinion would be safe to remove.. it just automatically fixes your network connection to the best one.
for example you have 3g turned on but the phone detects 4G itll switch to 4G
or wifi if found.
If you don't want to use it, that's fine, turn it off and freeze it if you want, but I wouldn't remove it. At the very least, hang on to a backup.
