Root Blobs that are different from BSydz ROM
dsmryder
Android Expert
Here are the drivers that I pulled from BSydz' ROM. I only posted the ones that are different. I hope that it can be useful. I hopt to vomit them into my ROM after I finish (whenever that will be) and see what happens.
ENJOY!
ENJOY!
These may or may not be useful depending on which version you took them from. I suggest you take them from the raw image file I posted in the reference section, to be sure. I did a lot of tweaking between versions, and some of the drivers got swapped through the process. I highly doubt our issues have anything to do with drivers though, I believe it is system related.
I agree. I just figure that it won't hurt to try.
I can tell you that a straight swap of all of the drivers from the Sharp image will cause cm9 to not boot up. I tried a couple of weeks ago. More experimentation is needed to determine which drivers are compatible and which aren't.
The question is, what would happen if we used the Sharp kernel and then replaced the libs? I added all the egl files to CM7 from the GB Sharp and they worked perfect. Still poking around with that.
Currently I have an update.zip recovery image I built based off the sharp 2.2.2 boot.img. I just need to test it out and see if it works later tonight.
What I plan on doing is installing his version 1 and pulling those to see what comes up. Should I uncomment the parts in the script to pull the drivers that were commented out? Have you guys already done this? I don't mind just trying and failing, I just don't want to waste my time.
Also, what could I do to help more. I need direction. I have my phone project. And sense nobody said they wanted to help, I'm going to just go where I want with it. Starship Triumph form klehman215 looks good.
i would like to see the sharp launcher ported..that launchers amazing in my opinion. i still like the xperia home s launcher better since its simple fast and doesn't hog and ram at all! the sharp launcher though caught my eye..it looks feels great. would it b possible to port that launcher to b usable.....
OK so I got a new version up with everything fixed. I figured a lot of stuff out.
The only Sharp drivers that don't work between the ROMs are the wifi and bluetooth. Let me explain. On our phone, the bluetooth is not functional with the Sharp kernel and drivers, but everything else works fine. On our phone, with the modified Triumph kernel and sharp drivers, everything works except wifi. But, to get wifi working all you have to do is swap out libra.ko. I hope this helps anybody trying to figure this stuff out. Might have to put up a Q/A thread about this stuff. Oh, and I found things in the Triumph ramdisk that talk about settings for the pmlog so they can snatch them later or something to that affect.
so does the camera drivers work? i really like that feature of zooming in and out with the volume buttons.
