http://androidforums.com/spectrum-a...uattrimus-jb-cm10-1-aokp42-9.html#post5587798Where could i find the CM version your using? I can't find any that early.
Just a question but is there a folder that i can pull from this rom to one of the nightlies to get bluetooth working?
Just thought it could be done since they're both 4.2.2
Then I'm mistaken. I thought it was 4.2.1 for some reason.
No idea how it works on one and not the other then, since the quatrimus builds were rolled up to official status (basically)
If im not mistaken this was the last build that had bluetooth working(4.2.2), then the cm10.1 preview came out, then the nightlies and it hasn't worked since this one(beta 4)
I tried the 5-7 nightly and my bluetooth still was acting up!
I tried cm10.1 rc this morning (dirty flash) it let me connect to my bluetooth and I could disconnect and reconnect with no problem, but as soon as I made a call the audio switched to the phone and the bluetooth disconnected and would not reconnect!
Logcat please.
Was there a change to Bluetooth on the rc?
Our are you just looking for logcats off Bluetooth when it's actually acting up?
Sent from my VS920 4G using Tapatalk 2
No change on the rc. But I just submitted a change to fix at least part of the issues:
https://github.com/CyanogenMod/lge-kernel-iproj/commit/39fb0081cfbc6539e9afe8ada0ae20f2c1308408
This should prevent bluetooth from turning off and refusing to turn back on.
Try tomorrow's build, if there is one, and let me know how it works. All three projects (CM, AOKP, PAC) use the same kernel repo so use whichever you like.
Get me a logcat and repro steps for any issues you have.
