Help Bluetooth issue with Note LTE
I've looked around but I haven't found a clear answer to this.
Has anyone else had a problem with connecting a bluetooth headset to the note? Specifically, keeping it toggled on or of when you turn the bluetooth off.
It remains paired, but when I paired it for the first time it didn't ask for the pairing code, and when I shut my bluetooth off, and then on again, I have to go into the bluetooth menu and turn it back on manually everytime.
Is there a fix for this?
No fix that i have found other than just leaving bt on.
The skyrocket has the same issue
