Root Bluetooth Issues
Today for some reason my phone will not dialout when my bluetooth headset is connected and i have started to get error messages about the bluetooth service failing to start and it is also crashing. I am wondering is i need to reinstall that and if so can someone post the bluetooth software from the phone that would need to be reinstalled.
I have already hard reset my phone (need to re-root now)
Have not installed anything really to the phone and still same issue.
All help would be greatly appreciated
The exact same thing happens to me. The Bluetooth recognizes the headset but when i try to make a call everything freezes. The headset works on my blackberry and my wife's optimus. I really have no idea how to fix this but it's been like this on both of the esteems I've had. Let me know if you figure out a solution. My headset is a Samsung HM1000.
My LG Esteem Optimizer app on the market has a button called "Bluetooth Enhancements", it changes some bluetooth related background settings for some stability, adds some new profiles and stuff. I'm not making a guarantee that it will fix the problem, but it's a very good chance that it might. Root is required.
Fixit. I uninstalled the music app both picotty aps and all bluetooth apps and it started working corretly again.
I am rooted so i used a system app remover to back them up and then removed them. Rebooted and reinstalled, rebooted again and it was working correctly
what are the "picotty apps"? and which bluetooth apps did you remove? I don't think I have any bluetooth apps. I'm rooted as well.
Thanks, glad to hear there's a solution.
Music.apk
PicoTts.apk
TtsService.apk
BluetoothControllerWidget.apk
BluetoothOpp.apk
BluetoothPbap.apk
I did nto reinstall the MusicWidget.apk because i do not use it and got tired of it continually loading in the background.
I can't promise that it will fix your issue. But it is what I did and it fixed my issue.
Music.apk
PicoTts.apk
TtsService.apk
BluetoothOpp.apk
BluetoothPbap.apk
Can you please please help me I uninstalled all the apps listed here using titanium backup and I had them backed up as well but stupid titanium backup won't restore any app it says restoring but circle just spins and so I am left with no Bluetooth I managed to restore all the Bluetooth apps but music app I can't no matter how please help me also I was wondering which app you used and if you will be able to upload the backed up files made by that certain app please :(
Can you please please help me I uninstalled all the apps listed here using titanium backup and I had them backed up as well but stupid titanium backup won't restore any app it says restoring but circle just spins and so I am left with no Bluetooth I managed to restore all the Bluetooth apps but music app I can't no matter how please help me also I was wondering which app you used and if you will be able to upload the backed up files made by that certain app please I am begging :(
might want to check this thread out, http://androidforums.com/esteem-all-things-root/435963-metro-apps-restorer-download.html
this worked! uninstalled the 3 bluetooth apps and then reinstalled using the metro apps restorer and now the bluetooth works great! Thanks!
Thank you so much you are a life saver i didnt use the restorer rather i was missing the music.odex and the original and uncorrupted music.apk which is why i could reinstall no matter what but thank you so much man i really am glad and appreciate your help very much
your welcome...:)
glad you up and running...:)
Thanks for all who posted in this thread. Had the same issue and had to factory reset my phone to get everything back in order. Once I re-rooted, I started taking out applications until I found the one that broke the bluetooth. Whenever I froze Music 2.3.4 my headset would no longer work. That seems to be the culprit for me.
Very helpful forum!
i forgot to backup the apps before uninstalling and i cant find the 3 bluetooth apps anywhere somebody please tell me what i have to do. bluetooth is essential for me. any help is appreciated
Don't worry. I currently made a backup from my phone. Here is the there files, just extract these three files to sys>app/ folder in your phone.
Still no luck fixing bluetooth. please any help will be greatly appreciated.
I am rooted. I deleted music apk. and Bluetooth now freezes when playing poweramp with car.
I have tried to putting music apk. and odex. in sys but still not working. I feel like dropping off a cliff already. please a more through explanation would help. what file manager? how to reinstall?
FOR MONTHS I COULDNT GET MY HEAD SET TO WORK AN DIDNT KNOW WHY! NOW I SEE ITS BECAUSE I FROZE THE DAMN STOCK MUSIC APP!!!! LOLOL
Now my friend you are rooted, I suggest you reinstall a rom an DONT delete or freeze the stock music app!
I have Jet Sound Plus and notice when I exit the program that in apps music.apk is on when I look at it. I'm sure the music apps we add to our phones directly use the stock music.apk when we play music.
Please, can you step-by-step this instruction. Please, please, please. (I don't know where to find "sys>app/folder" )
Thanks.
