Help Bluetooth Pairing....
Stick405
I'm having problems maintaining my BT connection to my Garmin 665 Gps...This is on my Goldwing... The unit is on the handlebar and the phone is in a cradle right next to it... I have flushed the BT connection on both units several times and restarted... It wont maintain the pairing... I have to keep redoing the pairing code... All my other phones have worked like a champ.... Maybe something in the settings or something.... The GPS is pretty well bullet proof... and I don't think it is the issue... Thoughts?... :)
Hi I was hoping someone else would jump in here, I feel im monopolizing things :D
Ok what rom are you running, I read about stock 4.2.1 having bluetooth drops on the nexus 4 the update 4.2.2 seems to cure probably most peoples problems I have been on CM10.1 since day one of owning the phone so I really dont know anything about that. I do know with this rom I have never had problems pairing to bluetooth.
I think I solved the problem..... I connected BT several times... didn't miss a beat.... Went riding for an hour ... didn't miss a beat.... What happened... The GPS asked permission to load all my contacts.... I said "OK" ... connected.... next time I had to pair again.. same thing... Asked for permission to load all my contacts.... I said "OK"... This time I checked the box which said "Don't ask again" Seems that solved it... It just goes straight to BT now. Cross fingers... .... Cheers...:D
