D
Deleted User
Guest
Hi,
I am having trouble tethering my phone to my computer via pdaNet and bluetooth (USB works fine). I've seen several threads and tried a lot of things, but nothing seems to solve my problem. I have tried under Mac OS X and Win XP...
Under Mac OS X, it detects my phone and pairs successfully. It gets to the point where it says "Select the services you want to use with your mobile phone" and I check "Access the Internet with your phone's data connection." When I hit continue, it say "Configuring services..." forever, and it never connects.
Under Win XP (same machine), in my Network Settings, I tried to search for my phone and it doesn't find my device. Alternatively, if I go to Control Panel -> Bluetooth, it will pair. However I then go to Properties, Services and check "Dial-Up Networking", hit OK, and it says "The parameter is incorrect"
So basically the problem is that although my phone and computer can see each other via bluetooth, the DUN service from my phone isn't recognized by my computer. I have tried this with another computer as well, with no luck. Is there a setting on my phone that I need to change in order to get this working?
Thanks!
Jeff
Thanks!
Jeff
