eddiesox
Member
Hey guys.
I'm fairly new to the optimus, just switched over from a crappy transform. So far I've only had one problem. Once my bluetooth is on it can't be switched off. Whenever I try to switch it off the phone freezes and reboots. Same when I try to turn on airplane mode. Seeing as I don't use bluetooth and its a major battery drain I would lie someway to turn it off. Any suggestions. I guess I should mention that everything is stock on the phone.
Thanks in advance.
Thanks in advance.
