Did an update of su binary after root and it messed up my root access.
Re-ran OCR and all is well again.
FYI I would stay on 2.3.1
I tried this four times and i cant get it to work. when i run warpdrive.bat it says this
SU Binary will not update.
Update failed. Try again?
Downloading manifest...okay!
Latest version = 3.0.3
Checking installed version = 2.3.1-ef
Fixing database....fail!
You can run apps like root explorer and adfree. In general it allows you to use apps that require root user permissions. Try adfree app from the market and you will get the idea of the possibilities. If you play games like angry birds with the ads in them adfree will cut them out.Ok the root is done.....now what can I do with it lol......first time I had a phone with root
OCR for ZTE Warp
Using zergRush
(All credit for exploit go to the creators)
One Clicks Done by
Interdpth and Shabbypenguin
rm failed for /data/local/tmp/boomsh, No such file or directory
rm failed for /data/local/tmp/sh, No such file or directory
cannot stat 'zergRush': No such file or directory
Unable to chmod /data/local/tmp/zergRush: No such file or directory
./zergRush: not found
Wait for phone to reconnect...
* daemon not running. starting it now *
* daemon started successfully *
mount: Operation not permitted
cannot stat 'rootsetup': No such file or directory
Unable to chmod /data/local/tmp/rootsetup: No such file or directory
/data/local/tmp/rootsetup: not found
rm failed for /data/local/tmp/rootsetup, No such file or directory
Copying files onto phone...
cannot stat 'su': No such file or directory
cannot stat 'Superuser.apk': No such file or directory
cannot stat 'busybox': No such file or directory
cannot stat 'remount': No such file or directory
Setting permissions...
Unable to chmod /system/xbin/busybox: No such file or directory
Unable to chmod /system/xbin/remount: No such file or directory
Unable to chmod /system/xbin/su: No such file or directory
link failed File exists
Installing busybox...
/system/xbin/busybox: not found
Cleaning up files...
rm failed for /data/local/tmp/zergRush, No such file or directory
You should have root!
Have a wonderful day!
Press any key to continue . . .
It almost looks like you're not running the root tool from the right directly. Unzip it, open a DOS shell, change to the directory where it's unzipped, and run it from the command line there.
Thank you it worked! i am now rooted, you guys are awsome.It almost looks like you're not running the root tool from the right directly. Unzip it, open a DOS shell, change to the directory where it's unzipped, and run it from the command line there.
