Root [Boost Mobile] Anyone buy this ZeroLemon 7000 mAh battery?
I think that's moar rom doing it, I have the same issue. Moar has some little quirks here and there. Mine charged and had the blue light as that's what i set my full charge color too is blue, and the phone said 79% in notification bar.....out of curiosity I unplugged it it magically popped to 100% when I unplugged it. When I went to work and let it sit a bit it slowly trickled down to 79% again, kinda like 2-3% drops, but in a matter of around an hour. After that it drained fine.
This combined with the call quality thing I think I'm gonna have to let moar go sadly.
My call quality is just fine in all ways, (bluetooth, phone, speakerphone)
As for charging, when I plug back in it just slow charges back to 100 which could take a few hours and then slow discharges at a normal rate, actually I can use the phone for about a 1/2 hour straight before I even see it drop to 99.
Still wonder about my other questions?
I just noticed in the Android tuner module under battery, I just changed the stats from 2100 to 7000, that could be why it stops and say 100% when 2100 is fully charged and when leave on charge, even though 100% it keeps slow charging the rest of the 7000. Will see on next charge if that does anything, Will have to wait a while though its fully charged now.
Still wondering about the fast charge though?
Sorry,The fast charge is in the other kernel not in a module. I'm on the stock one now.
After I do a full charge and then it says 100% unplug then the percentage goes down then I recharge again and it gets to a 100% again for a full charge then I can go this long before it even decide to go to 99% and it still hasn't even got to 99%.
Finally found the wanam setting so I can use the camera on Moar8.0 when below 15% and even tried @ 5% and works fine. I am also doing another charge and will see if it fully charges with the settings for the size of the battery that I changed. On this last charge I got 6 full days with using the phone about 4-5 hrs every day. I go on twitter, the forums, tapatalk, use the internet, use maps, and talk to my wife everyday for 1/2 hr at lunch using bluetooth, ect. Had to plug in to save something so have no screenshot of time. Very happy with this battery!:D
I ordered a ZeroLemon 7000mAh battery for my Galaxy S3 and received it 2 days ago. This is the first time I charged it and I followed the instructions by charging it for over 12 hours before I used it the first time. I had to leave it on the charger for about 3 hours after the % reached 100% before the LED turned blue and indicated it was fully charged.
Right now I'm at 1 day, 4 hours, and I still have 61% charge remaining. The screen time on is at 4hrs, 0m, 25s. This seems pretty good!
But my question is that the battery has NO indication of its capacity written anywhere on the battery. Take a look at my pics. There is nothing written on the battery or literature that came with it that says 7000mAh or 26.6W (3.8V x 7000mA). It just shows the voltage.
How do I know that this is the 7000mAh battery and not the older 6300mAh version?
ZEROLEMON RUGGED CASE SAVES THE DAY!
I dropped my phone a bit ago and it hit on the top corner. This case is reinforced with rubber that is more dense on the corners which is there specifically to protect against drops like the one my phone just took. My phone literally bounced when it hit, then ended up on its back. The case absorbed the shock of the fall like a champ!
This Zerolemon rugged case just earned it's $19 price tag. My phone would've been toast right now if not for it. The screen most definitely would have cracked not to mention possible hardware damage.
If there are any of you sitting on the fence about purchasing this case. Let me reassure you. This case is no joke! It is well built and does exactly what it's designed to do.......... protect your S3.
I'm getting ready to write Zerolemon and let them know what an awesome product they have.
Bought the zerolemon rugged case. Great way to spend 20. Was gonna play operation with my otterbox. Glad I didn't.
Thanks for the recommendation, wetbiker!
No problemo. I came very close to playing operation with my Otterbox too. LOL!
You may or may not have to remove the small plastic piece that runs across the top of the case face. Mine messed with my proximity sensor and the screen would not come back on when I pulled it away from my face during a call. It was OK with TouchWiz ROMs because the home button would activate the screen. Not so with the AOSP ROMs. If the screen turned off during a call it could not be turned back on. I took a pair of wire snips and snipped it off. Easy peasy. It's removal did not affect the integrity of the case at all. I'm using Tech Armor screen protectors too. After seeing how well these screen protectors work, I will buy them from now on. I followed the instructional video on the Tech Armor website and my screen installed flawlessly. No bubbles at all. Their screen protectors also come with a great warranty.
There is no doubt in my mind that this case saved my phone the other day.
Yeah, I drop mine a lot too. Cuz I'm a clumsy goof. Lol
I did remove the back and top covers.
Back and top covers? You mean the back snap in piece used for stock batteries? Did you remove the small plastic piece on the top of the front too?
Correct. The back cover for the extended battery and the whole plastic cover on top (front). Included the red piece over speaker.
Edit: I do have separate screen protector on phone in place of the case's.
Wow didn't know about the Zero Lemon rugged case. I've always used the plain black one which looks nothing like that picture.
Guess I'll be ordering that now.. :)
It's nice bro. If you look at the top of the picture I just posted you can see where I snipped the piece off.
Here's a stock photo with the plastic piece on. This piece messes with some people's proximity sensor. It's easy to remove.
It also comes with a holster/ stand.
It's an awesome case and I highly recommend it. Not only does it fit the 7000mAh battery, it also can be used with the stock battery.
Very nice!
Built in screen protector, I'm reading.. how does that feel when using the touch screen?
I removed the built in screen protector. And use the one directly on the phone (cheap one from eBay).
Just ordered a pack of tech armor ones.
Didn't like the built in screen protector on the otterbox. So imagine it's the same.
Very nice!
It felt great. I went ahead and took mine out though when I snipped the plastic piece off. I went with Tech Armor screen protectors. I'll never buy another brand because these things are awesome. It's what is on mine and as you can see in the 1st pic, there are no bubbles at all. They come in a 3 pack for about $7.
Read this -
Tech Armor Samsung Galaxy S3 SIII Anti Glare Matte Screen Protector 3 PK | eBay
LOL..... I hooked my old LG Marquee up to take those. I tell you what...... I love that old Marquee. It feels great in my hand and it's just an all around good phone. I'll probably never sell it. :D
Lol, I know I have an old camera in a closet somewhere. I'm just at work right now.
I never need it. My phone is a better camera. Lol.
