Yes charge it to full capacity (100%). And then unplug. Charge again until it says 100%. Do this within 5 minutes. Once done go in to cwm and wipe battery stats. Then use phone as usual until it is completely dead. Charge to 100% without interruption, using your phone, and then see if that corrects your problem. You might have to do this a couple times.
For future reference it is wise to do this everytime you flash a new ROM because it's a factory reset and our battery stats are reset also.
I hope this helps you. Please report back if it does or doesn't.![]()
