Root [Boost Mobile] beats audio
its just the one app i got from the market but it sa it will just uninstal notifications not the drivers
The beats installer app places alot of drivers (mostly useless) in your system. I would suggest if you made a backup, revert to it. Otherwise open the .apk like a zip file and look under assets & thats where you'll find what it installed & go you can search and manually remove it, however I believe it overwrites some system files which would be bad to delete, so reverting to a good nandroid backup is your best bet.
What app is it? I didn't know any apps actually worked to install beats worked
Lol yeah Apollo,, you can definitely install beats.. However there are fake ones floating around.. The real one sits in the notification bar..
does the beats you installed work correctly? does it make a differnece? im curious as i have never used the market beats installer before
I can't remember if I got mine from the market.. I do think it's more of a bose sound in headphones.. Like you can hear every flick of a guitar.. Or beat on a drum. I like it.. I also use volume plus and shin has xloud script.. My phone as a whole definitely has great sound quality. But I'm not sure which source to give credit to
