Root [Boost Mobile] best roms for wirless tethering ..
what are the best roms to use that open up wireless wifi tethering..I have the ZTE warp "rooted "/Boost mobile .. I was able to get it to connect useing blue tooth , but really slow ..
i have tried all the apps. but they don't seem to work .So i was wondering if i needed a specific rom ..I have the phone rooted ,but still using original rom ..
If I use a different rom , what app. will work the best ..
suggestions ? :confused:
thanks.
My ROM has the wireless tether app already installed and it's working fine too. I think it's working w/o problems on most ROM's.
so which roms already have the witless tether app. installed ?
I know you want quick answer's and you want them NOW!! But listen, It is a good idea to read through the threads and find stuff on your own. The answers to the question you justed asked and a WHOLE LOT MORE!!:) You will be a lot more knowledgeable after that and glad you did it. ;) Dont get mad at me. Just do a little homework, it will help you in the long run. :D
i know we have barnacle wireless tethering working and thats all fine and dandy, but i want to know how i would get one of the other wireless tether programs working that put out infrastructure mode, cause my laptop has a bit of an older wifi card in it and it wount allow internet connections through barnacle ad-hoc tethering, just local. i can tether with my data cable all day, but i would just like to see the infrastructure mode working because i would like to use it more. so any ideas on how i would do that?
