Root [Boost Mobile] Can't boot into cwm
bsmith84
I have rooted my phone and everytime I try to boot into recover for power volume down I get ftm and when I push power volume up I get a basic recover I downloaded root checker and everything is rooted I really need some help here I know I have root cause barnacle tether works fine
Welcome to AF, bsmith! I have moved your question into the Warp All Things Root section. You should get more knowledgeable help in this section. Thanks for understanding. :)
Try an app called "Quick Boot", it will allow you to boot into recovery from the homescreen just by clicking on Boot Recovery. Let me know if it helps
I Have a question. I put Superuser on my Warp, also CWM. When I tried to add the Shinjitsu Rom the only screen I see when I turn it on it the symbol of the blue circle with Shinjitsu Rom OC in it. Anything I can do? Any help would be appreciated.
when you flashed the shinjitsu ROM did you clear dalvik and cache? have you tried fixing permission? please take these steps and report back so i can assist you further :D
I did clear the cache, three times, and the dalvik. I believe I had the permission fixed as well but cannot be certain. The problem I'm having now is the only screen I can see is that one with the blue circle and the Shinjitsu logo. I cannot access the phone itself to turn on USB storage or boot into recovery mode via quick boot.
Okay try reflashing the ROM itself if not downgrade to B08 and then try again
OK, but my question is how can i reflash the rom w/o being able to access the SD card or my phone? Am i screwed? lol
Will try, if that does not work...I do have a warranty through Geek Squad, what if my phone accidentally fell out of a second story window, they'd just replace it. Your opinion?
Nevermind, I got it into recovery mode. Thank you so much, I think I'll recognize my limitations and stop messing with this stuff! lol Just stick with neat little things like GO Launcher, etc....
