ztewarpcm7
Member
does anyone have the vendor files for the warp i have all other proprietary files to build except for the vendor one thanks in advance
Someone get this guy the vendor file stat!!!
Up thereas you can see i have all the files these are the one i need
[img=http://s17.postimage.org/bs7t2i6x7/Screenshot_2.png]
[img=http://s17.postimage.org/gfdv49ua3/Screenshot.png]
BoardConfigVendor.mk
warp-vendor.mk
warp-vendor-blobs.mk
well i actually found out when you use zte blade extract files command it uses adb to pull the correct files you need to build but i got an error saying it didnt find the device warp in the cyanogen repo
I've been trying to figure this out as well and I've never seen any of these files.
warp-vendor.mk
All we have is what QuietStorm has in his github. The Extract-files.sh script is part of that so you can get it from the link in Snake's previous post. Snake and I also got the error regarding the Warp not being in the Cyanogen repo. Had to take QuietStorm's files and save them to ./device/zte/warp. Once we did that, the build process worked as expected.
As a side note, I'm really glad to see someone else working on this. I'm close to the end of my rope trying to figure this out.
Edit: Oops...I just double-checked and I don't see the extract-files.sh script in the github. It's been a while since I started messing with this so apparently I grabbed my ver from another device. So it's highly probable that it is not configured to grab all the needed files for the Warp. I don't really use it though as QuietStorm has provided the majority of the files from the phone in his github and I just copy in whatever's needed after the build is done. Regardless, sorry about the bad info...
Cool. I really hope you figured it out...
I've also been spending lots of hours comparing the files and file contents of the blade and skate, both stock and CM7 and have nothing to show for it. Went through all the init-type scripts looking for files that were called and made sure they were included where the scripts were looking for them and it still hangs with no adb support. Since there's no adb, no error on the screen, and no way to validate that the updater script is even doing what it needs to be doing, this is really like finding a needle in a haystack blindfolded. I've read that adb is actually part of CWM for other phones. Anyone know why does the Warp's version not have it? Is the issue the version of CWM that was ported or just something that wasn't included in the porting process? (or something else?)
Anyway, I'm pretty sure I should have the necessary files needed to at least boot, but have no way of knowing for sure. (I have all the ones called by the init scripts...many of which were not added as part of the CM build process. I believe my issue is with the init scripts somewhere. My latest suspiscion is due surrounds the fact that the warp has an ext4 system partition. All the other CM7 init scripts I've seen are phones that use yaffs2. Would really like to how init.rc is configured for a CM7 port that uses ext4. Tried using stock partition settings in init.rc, but didn't help.
Anyway, unless we get some kind of logging ability, I probably won't be doing a whole lot more on this. If there was some kind of way to view logs & files on the phone (after flashing) I *might* be able to figure something out, but it is an exercise in futility at the moment. Someone with an actual dev background would not need to try reverse engineering everything and may do just fine. Devs have a much better chance of looking at code and being able to tell if it's right vs. relying on errors/logs to tell them it's wrong.
I got a build lying around that has adb working on it if you wanna try that.. however when you logcat it gives you a permissions denied error
