Root [Boost Mobile] DirtyRedz Warp Theme
dirtyredz
Also included is a modified version of Crackanug's "Call of Android" bootanimation (found here) with sound
(NOTE: to back up your original bootanimation, go to root directory-system\media, and make a copy of the "bootanimation.zip", then on to system\media\audio\ui, and make a copy of "Bootsound.mp3")
Screen shot shows statusbar icon changes and go launcher elegant theme, also magic lockers XDA theme, and WPclock
Credits go to kgill7 for his sweet statusbar icons that I used in this MOD from his Deuces CM7 theme found here
Download HERE
save to your SDcard, reboot to ClockWork Recovery, select install .zip from SDcard, then select choose .zip from SDcard and select "DirtyRedz_Warp_Theme_09MAR2012.zip" and install & enjoy!
now it just shows a crown with an x like there is no coverage but I called my work number and it rang so I must have coverage... I did clear cache and dalvik when I installed this from zip too fyi.
I do love the theme so if the crown works as an indicator I would def call this my favorite so far :)
I know that the blue theme and others had issues with the indicator not being included and had to manually place those icons in the zip when they used uot, not sure if you are using UOT, but I think this phone has funky placement of the indicator images compared to other phones... does the indicator work for you on the warp?
My theme didn't have any issues with the indicator. I also have a stock one so u don't have to flash a nandroid :)
Lol down, I see looking back them were fightin words... I do like your theme too :-) just have a soft spot for black /white themes
Not a problem I'll take it apart and look at it again. And no not using uot I tried that before and it didn't flash correctly so I built a new flash zip that works. Constructive criticism is good by the way:)
Sorry, wasn't trying to highjack, awesome work! I'll give it a test tomorrow
why can't we use the thank button more than once?
I love this theme!
hey, is it just me or does the middle of the crown look a bit like a... nevermind :)
YAY, the signal works now, cool!
I didn't get the bootanimation or sound though, not a biggie but they didn't come through for me.
Uot kitchen has a selection on the boot Animation screen for the location of where the bootanimation.zip is supposed to br placed, you need to select crayongen
