Root [Boost Mobile] Does anyone have the latest prl from boost >61010
Status
Not open for further replies.
MisterParadox
I replaced my prl and now it will not update back to the latest one. I have had the worst speeds in over 3 years with Boost and have tried everything possible in this forum. If I can get my prl back to 61010 then I will just suck it up and give Boost a call, AGAIN! No, I am not throttled according to them. I am on the daily plan and according to them it resets every day........any help would be appreciated. Thanks. :)
If you would have read my initial statement in this thread you would have known that I cannot update my prl after the change. Sorry you missed that.
I did read as a matter of fact, I'm just saying the update prl in settings should fix it... what rom are you on? I know some roms broke that function.
I honestly would not have posted this thread if the common sense idea of updating my prl was working.
I dont understand why going to settings/about phone/ etc doesn't work on the noob rom?
Since 61010 is a new one for us I dont think anyone has it in a zip file yet.:) Let me look around in some threads,:)
It would be quite easy to get by using the method posted above and hitting "backup" and then browsing to where the backup file is and then uploading it.
That dialing command is not working. Again, this is quite easy to do. Anyone, I mean ANYONE with this latest prl can simply back it up via DFS per the method above and upload it. I am sure you know someone with a dropbox account.
Mercury, Croy, Doc, Smartman, Dizzle,:)
Try making a nandroid backup, then flash Halo ROM, the update prl menu is fully functional in there. If all goes well then you can reflash noob, if it doesn't work then we'll have to extract a prl from one of the Warps in this community.
I started with the Halo Rom. I am not going to flash to that again. The problem is NOT that I do not have the prl update menu! I do. IT IS NOT WORKING! Anyone can use the method above and make a backup of their current prl and upload it. That is all I have been asking for from the beginning, the new prl.
I found this post.
[How-to] Change your PRL manualy and anything related about prl's - Android Forums
Inside is a link to his drop box account with lots of PRL'S, download it and look inside. here is the link for the dropbox.
https://www.dropbox.com/s/jotogv7dbtzxvu8/SPRINT+PRLS.zip
Best I can do. :)
I searched everywhere and can't find the 61010 PRL. Someone with that one will have to extract it... I'm on 61007, sorry...
i just made a backup of 61010.prl.... not sure how you want me to get it to you. shoot me a pm to figure it out.
You need a dropbox or media fire account to upload it to, then post the link here. :)
Then he can download it.;)
Status
