can someone post a link for super extended power menu with screenshot and quick reboot
I pulled the following files from tweak nation..
/system/bin screenshot
/system/app screenshot.apk
/system/framework framework-res.apk
/system/framework android.policy.jar
Made flashable http://db.tt/6APmfj9I
It doesn't work keep getting error code
Success! Wow. The screenshot bin file has some funky permissions. I added the following line to the update script of this installer package.. " set_perm(0, 0, 6755, "/system/bin/screenshot");" and success!! Here's the new flashable..
http://db.tt/Larg2Hl1
keep in mind that the framework res in this installer is ICON based.
It didn't give me an extended power menu but changed all my icons
Could you describe the "extended power menu" you are trying to obtain because I feel you may mean you are trying to get is the quick panel settings menu that is at the top of the notification bar.
and the pull down menu
are two separate things. What one are you trying for?
You MAY have to do a factory data reset, then reflash the rom you were using.
If, after that, you still want the extended power menu, use a rom that already has it.
I've already done that a few times. Still doesn't work and I don't like the other roms. I like the style of the icons that comes along with the extended power menu. (I think it is from icon rom.) I use rom toolbox pros rebooter, so it's not that big of a deal to me. But it would be nice to have it working properly.![]()
