Root [Boost Mobile] Flash on during video
That's a good flashlight app if you're running stick but the led flashlight on Google play is just as bright and has a widget...there is no comparison...
And I use it in the background all the time with the camera for video or with my fast burst camera
I've found that the brightest setting on RootDim is the brightest flashlight for me. Plus you can run it as shortcuts instead of widgets running in the background.:D
Lol for that matter you can set the brightness to whatever you want through scripts and have a shortcut with smanager/smwidgets
