Root [Boost Mobile] force closings
R0k5tr
Member
having a problem with my jelly bean keyboard (vllwp) force closing, it doesnt even show the keyboard, and my status bar closing when i use the swipe to clear B10
SWVersion
N860V1.0.0B10
If you go into settings->applications->manage applications-> and find the keyborad, you can wipe the cache on that app and it should remedy the sittuation... I take it you restored the keyboard with titanium backup after updating?
got they keyboard to work, still having problems with the status bar when i use the "swipe to clear" and the camera also force closes
How did you get the kyboard to work?
settings/language and keyboard, select the keyboard you want. Back out.
go to your mms/sms app long press the area you type in and choose input method, then choose the keyboard again.:D
  • Like
Reactions: Doc
