Root [Boost Mobile] [GUIDE]Easy Root Method - Works w/ B10 update! 1/28/2013
When I type "adb reboot bootloader" it reboots and hangs. It does not ask for any driver. When I type "fastboot flash recovery c:\recovery.img" it just says searching for device. That's the step I can't get past.
when I try to install the driver
Gonna sell this phone now - how do I uninstall root? Thanks! And thanks for a root that made this phone usable while i had it!
Hey all - I am reposting this, in case someone can help me "unroot" back to stock so I can sell the phone.
I am only using it on WiFi -
thanks!
The original way was to run the update tool on the Warp, but it doesn't work anymore as it's no longer supported. I believe there's a stock rom zip that can be flashed that will undo everything laying around here somewhere... but then you'd have to give it the B10 update as well to get it fully updated and stock.
Just installed one click cwm root, immediately thereafter made a nandroid backup, then did a titanium backup. since this is all new to me, need a little help with two questions. one, do i need both nandroid and titanium backups? i think the answer is yes because nandroid gets the system stuff and titanium does not. even though nandroid backs up the user stuff, too, titanium is way more flexible when dealing with the user stuff. two, should i have cleared dalvik and other cache before doing my first nandroid or my first titanium backup? thanks, everyone.
You can restore apps from a nandroid backup through one of the menus in Titanium Backup. It just takes a little longer because it has to run verification checks on the backup first. But you are right about the flexibility part. As for clearing cache and dalvik cache, its not necessary to clear before making a nandroid. The backup will include those caches as well, and it won't really harm the backup/restore process if it goes uncleared :)
I'm try that and I have no play store it was not there after jb update can't seem to get it back
Ah, you flashed CyanogenMod 10 didn't you? Gotta read before you flash...
CyanogenMod is an open source replacement firmware for smart phones and tablet computers based on the Android mobile operating system. It offers features and options not found in the official firmware distributed by vendors of these devices.
Features supported by CyanogenMod include native theming support,[3] FLAC audio codec support, a large Access Point Name list, an OpenVPN client, an enhanced reboot menu, support for Wi-Fi, Bluetooth, and USB tethering, CPU overclocking and other performance enhancements, soft buttons and other "tablet tweaks", toggles in the notification pull-down (such as Wi-Fi, Bluetooth and GPS), app permissions management, as well as other interface enhancements. According to its developers, CyanogenMod does not contain spyware or bloatware.[4][5] CyanogenMod is also stated to increase performance and reliability compared with official firmware releases.[6]
CyanogenMod is developed as free and open source software based on the official releases of Android by Google, with added original and third-party code.
Here, We have built CM10 "Jellybean 4.1.2"
For the Zte Warp. its been a long time in the making since out LiquidSmooth release. Things are starting to come together though. There are still bugs, some things not fnctioning as they should, But i think you guys all know the situation by now.
This is PURE CyanogenMod, no Custom modifications to the system, except for those required by hardware
Current Stable Version, Beta 1.1
There are no more Milestone Releases.
This project has reached the point of Beta Quality, Which isnt bad at all
WHATS WORKING AS OF BETA 1.1
RIL / 3g
SMS
Phone calls
Wifi
Bluetooth
Speakerphone
Mic
Sensors
and other things
DOWNLOAD
Download BETA 1.1 HERE
CHANGELOG
BETA 1.1
Changes
Bluetooth Working
Wifi Working as it should, no lock up
DHCP working, no more static ip
Camera partially fixed, it now connects to camera, still has errors. but its progress
Fixed issue with settings no sticking
Apollo Fixed, doesnt FC the first time.
Eri / Netowork fixed, shows up as Boost Mobile
Fixed most of the issues with system stalling / freezing.
Kernel Updated
Switched to Frameworks Native from LegacyMod
Switched to Frameworks AV from LegacyMod
Webkit patched for smoothness
:D:D:D:D
CM10 Milestone 7.1 08302013
Changes
Frameworks Changes:
Transparent notification shade
Triggering EarlySuspend based on BackLight brightnes
Allow purging of asset bitmaps... ported from Froyo
Optimize gradient textures
Fix memory corruption in LayerRenderer copyLayer
Plug memory leak that happens when reusing display
Fix texture corruption
Use RGB565 surface for wallpaper
Prefer 16bpp formats for opaque bitmaps
Settings Changes:
Enable the NAVBAR
Add Option to disable boot animation
Add Partition info option in settings
Reboot Menu Changes:
Add Hot Reboot option
Add bootloader option
Phone Changes:
Add option to exit to homescreen after call
Trebuchet Launcher Changes:
Fix icon label shadow outline rendering
Milestone 5:
"Nightly-07252013 and up"
Fixed Sensors (Screen Rotation, Accelerometer, Light Sensor & Proximity Sensor)
Fixes stability from M4
Mile& stone 4:
"Nightly-05212013 and up"
Audio Routing Fixed
Most Of The System / Apps Are Now Hardware Accelerated
APNs / MMS partialy fixed
New Kernel .went from 2.6.35.7 to 2.6.35.14
WiFi seems to be more stable
Added Hot Reboot Option to reboot menu
Added Bootloader Option to reboot menu
Ramdisk and permission Fixes
Fixed some lag issues.
Milestone 3:
Fixes some stabillity, Fc issues, Permission changes, Play store Working Better "Nightly-05162013 and up"
Milestone 2:
Fix USB Mass Storage "Nightly-05152013 and up"
Device Tree:
Overlay Changes for mounting of sdcard
Overlay changes for Power profile, Apns, Storage, and hardware
Complete Ramdisk Overhaul
Libhardware_legacy: Wifi.c fixed to load Wifi modules on boot
Build Libaudio from source, fix alsa audio
Switch to WPA Supplicant 8 from Ver 6, Networks are more stable.
Backport Libnetutils from cm10.1 to cm10 (better net performance)
Coded & added the WarpedParts app to calibrate sensors (when sensors are fixed)
Baseband is now seen by the rom..as it should be
Other misc tweaks / rewrites
Thanks
Hroark13, Downthemachine, Jetx2x, TattooedGod, Jssa28, Phenomx4, Dm47021
Dm47021 & Downthemachine did all of work to kernel and most to the device tree. We couldnt have done it without the other guys too
On that note, Dm4721 and Downthemachine..Never hated eachother, it was just a big publiclity stunt lol
Google Apps Package
DOWNLOAD: Download Here
Updated Google Apps Package
DOWNLOAD"Tigatron" UPDATED GAPPS PACKAGE
Donations
If you would like to buy be a beer, Jaegermeister, or just feel the urge to donate
DM47021
iF you would like to donate to the other guys, let me know... and ill get their links posted
ENJOY
Also Check out the Team Osiris Webiste Team Osiris Development
Everything was in the very first post. Camera doesn't work yet in the rom because well its a kernel issue thats being solved slowly but surely. PlayStore isn't in there because you don't have gapps (the google apps package) installed, which you should have downloaded before installing the rom. There is a link to a good working 4.1.2 gapps package towards the end of the thread though.
Didn't work keeps saying gallery has stopped I must of messed up on root or jb update don't know what to do help please if anybody knows what can be done to fix this plus no play store
Once more; not root related, but rom related. Everything is (again) in the first post of the rom thread, including camera, the playstore/ missing gapps, everything. If you want play store, calendar, mail, etc., you will need to download a separate gapps package and flash it on top of the rom.
So I should do it over again and that should do the trick I'm wait for the link on gapps from u than I'm download what u just posted hope it works thanks dude ur the man please post gapps link so I put gapps first then jb cm10?
camera won't work after a reflash; remember, CM10 is still in beta stage. Some things don't work as they should, and it'll be some time until things are fixed.
This link will take you to the rom thread/ the post where I have the gapps link. If you need any further help with the rom or you have questions, the following link is where you need to put it to keep this thread clean and only for questions regarding the rooting process for the Boost Mobile Warp:
http://androidforums.com/boost-mobile-warp-all-things-root/720431-beta-1-1-team-osiris-cyanogenmod-10-jellybean-4-1-2-zte-warp-33.html#post6311450
Overview:
Rooting is now a one step process for the original Boost Mobile Warp!!! This method works with the B10 update that was pushed out between december 2012 and february 2013. Download one of the two zips below and install update from stock recovery. This will give you Root, install a custom recovery of your choice, install the data fix, and make custom recovery stick from that one single step. I have personally tested by going back to stock using the ZTE software update tool and trying it multiple times. Note, if you have Public Mobile this method will not work, please see post two and try the other methods, please do not post to this thread concerning Public Mobile or other carrier versions of the Warp.
Detailed Instructions:
  • Download a zip with the custom recovery of your choice, and save to sd card:
  • With phone completely shut down press and hold the power button and volume up button at the same time until you see the android system recovery
  • Choose Apply update from sd card (use the volume keys to go up and down and the camera button to select)
  • Choose EasyRootCWM.zip or EasyRootTWRP.zip and hit the camera button to run
  • Reboot and enjoy root/custom recovery!
Both recoveries work great, personally the touch recovery is my favorite, I extend very special thanks to Hroark13 over on xda for porting this recover to the warp and Team Win for coming up it in the first place, please drop by over on xda and give Hroark thanks for bring us TWRP, if you don't know he was legendary over here for getting kernels going etc for us and we would be way further behind where we are today.
Special thanks to these three for finding this method:
wilm804xx
Downthemachine
Jetx2x
someone please help it is saying device not compatible when downloading twrp on boost zte n860
Sorry not all of us are geeks but I do have a doctorate.
Yeah, not the issue. I'm not looking down on you, being a geek isn't required, and I have one as well.
I'm just trying to clear up the communication.
In the post you quoted, there was a non-Play Store link provided to EasyTWRP, with instructions on where to put it and what to do to make it work.
Is the Play Store problem happening after you did that, or did you try the Play Store instead?
If instead, please try the instructions you quoted.
If it's happening after the EasyTWRP installation, could you please give me the Play Store link or the exact name there (with developer's name would be great) so I can check your exact steps?
Welcome to the forums! :)
PS - you're on Boost, yes?
I just tried to install EasyRootCWM.zip and EasyRootTWRP.zip both of them gave me the following error message.
-- Install /sdcard ...
Finding update package ...
Opening update package ...
Verifying update package ...
E:signature verification failed
Installation aborted.
And I didn't unzip the files so I don't understand why its not working my SW Version is B10 just like this thread entails please help me I would greatly appreciate it :)
