Root [Boost Mobile] [Guide]How to change your MSL and PRL (Not CDMA Workshop)
marke123
Member
If you don't know what an MSL code then you don't need it :p
If you need it, here's how to find it on the Warp with Gingerbread 2.3.5
Following the directions in this post with caveats listed below:
http://androidforums.com/htc-hero-s...thout-calling-sprint-using-cmda-workshop.html
When you open aLogCat, click Menu, then Filter.
Set a filter on the word "code" without the quotes
Wait a few seconds or more. Or go to phone and trying ##3282# again, select Edit, then Cancel. Go back to aLogCat, look at the results. You'll probably see two 6 digit codes listed. One of them is your MSL.
Go back to your dialer, enter ##3282#, select Edit. Try each code. One of them will work.
Be aware that if you enter the wrong MSL twice the phone will automatically reboot.
Just as I suspected, MSL Reader from Market fails miserably - doesn't pull the MSL even with root access. Probably because ZTE goes to significant lengths to obscure info on the Warp phone.
We tried several typical "getprop" commands yesterday with adb to try to find the MSL, none worked. So far the only solution that does work for sure it the one I posted above.
Hey marke....still can not get this to work for me. I let logcat run for like 2hrs! I paused and filtered the words.."code" "msl" etc the log just remains blank OR it does not give me anything useful wtf am I doing wrong. I followed the directions
Moderator note 1/6/2013- changing your MSL is a VERY bad idea. EarlyMon
You must already have your phones msl code for this to work
Click the link below to download DFS. Its a fully working demo
that you can use as many times as you want plus its better then CDMA Workshop and totally free
Download CDMA Tool DFS software.
DIRECTIONS
Using your dialer dial *983*87274#
Choose Only Diag or if your only internet is tether (like me)
Choose All Functions
Open DFS and wait till the countdown completes
If you did not see which com port your phone installed to. Dont worry DFS knows.
Click on the port button
Now in the port list look for ZTE Handset Diagnostic Interface and double click it once there's a green circle next to it its activated.
Find the SPC box and type in your MSL code
Click the blue circle next to the word SPC to send the unlock code
If you entered it correctly this is what it will say on the log
window
Click on the programing tab to get to the SPC edit area
From here go down below SPC where it says STR and enter any six digit number you want your MSL to be in the white box.
The last thing to do is to click the red write button and your
finished changing your MSL just reboot your phone for changes to take effect
You can also click reset in DFS to reboot
TO CHECK IF IT WORKED
When phone reboots open DFS
Go to place where you input the MSL code and test your new code and see if you get the unlocked successful text in the log.
Or find a place that needs your MSL code in your phone and try it.
If it works open dialer again and enter *983*87274# and this time choose AT or usb will not work.
TIPS
Write down the original MSL code in case you need to change it back later.
I am not sure if your new MSL has to be 6 digits or not.
The MSL can only be numbers.
I would call the dial code leaving out the last # first
Then in your call list hold down on the number click edit
before call and just add the last # so you dont have to
remember the code or dial it.
If you enter the wrong MSL more then twice your phone will ether freeze or reboot.
I am not sure if you have to be rooted or not
I take no responsibility if you mess up your phone doing this if that is even possible.
DIRECTIONS
If you did not see which com port your phone installed to. Don't worry DFS knows.
window
Locate the nam tab
Now its time to backup your original prl in case one of the flashed prl's cause you to completely lose signal as to where you cant update prl from the phone its self.
Click the blue button labeled read under the prl section.
Once your prl shows up in between the box above the read/write buttons and the world enabled, click save and save it someplace safe.
Now that's out of the way its time to flash a prl to your handset.
Ether put all of your downloaded .prl's into the prl folder located in the DFS installation folder. (this allows them to show up under the local tab in the prl area). or just click the load button and navigate to where you downloaded them.
Once you have the prl that you want to flash loaded click the red write button to flash it to your phone.
The log box should look like this in the picture below.If everything went ok every thing in list will say ok.
The final step is to reboot your phone click the reset button at the top if you don't reset you will not have a signal at all
If everything was successful open dialer again and enter *983*87274# and this time choose AT or usb will not work.
RESOURCES
The prl files can be found here
Index of /prls/Sprint
A analysis of all the prl files can be found here
BatonRougeBroadband.Info - Home
Speed test app to test your speed
https://play.google.com/store/apps/details?id=org.zwanoo.android.speedtest&feature=search_result
How to find your msl code
http://androidforums.com/zte-warp/450475-how-get-your-msl-code.html
TIPS
(Once I download all the prl files Ill rar them and upload them all in one rar so you can put them on in the prl folder of DFS so you will have them all)
Here are my results so far for fountain/ludington which is in northern Michigan
i plan on testing every prl
Original boost prl signal 1 to 2 bars using speedtest app .50 to .73/mbs ping 386 ms
60686.prl no bars to 1 bar sometimes 2 the bars were white no 3g stayed on white 1x
60683.prl -- signal showed about 2 bars steady sometimes +1 bar 1.23 to 1.32 mb/s ping 310 m/s ? full bars when coming back from screen off but then drops back to 2 bars?
60711.prl ping 317-344 ms signal steady 2 bars some times steady 3 bars intill speed test app was launched then droped back to 2 speed .73 to 1.23mb/s mostly around 1.11 mb/s
60681.prl ping 324 to 345 ms speed .90 to 1.23 mb/s mostly 1.23 mb/s signal 1 to 2 bars mostly 2 bars steady
60680.prl ping 342 ms to 364 ms (mostly 3.63 ms) .56 to .72 mb/s ( 1.02 mb/s when 3g was full) signal switched between 2 and 3 bars constently 3g signal was only full on one test
60679.prl ping 344ms to 347 ms (mostly 347ms) speed first test.38 mb/s after that .92 to 1.27 mb/s signal sometimes full 3g signal 2 bars steady sometimes 3
60678.prl ping 460ms to 494ms 430ms speed .30 to .44mb/s signal 3g low steady 1 bar sometimes 2
maybe, maybe not changing the prl works on all phones the only problem you mite have is the dial code so try the dial code in my guide if it dosent do anything then you will have to look up how to put ur phone in diagnostics mode i know the samsung transform ultra has a different dial code because i just helped a frien do this last night
so reaserch to find the dial code for your phone if mine dosent work if you cant figure it out ask me an dill see what i can do
try this on first i think it will work Dial ##7678#
Enter your MSL
Select DM and your phone should reboot in DM mode
its the one i used on the transform i read it works on the prevail
that is if your phones running gingerbread
I may be doing something wrong.. But I downloaded from the link you posted and I installed all the crap.. Now it wont post up the cdma tool. It's asking for an Id and money.. c'mon bro help me out.
yeah that happened to my friend when he was doing his transform ive never seen that screen not sure why
So I've seen people borrow 3G information from donor phones and put them on other phones, like, umm, the Touch Pro 2. I figure this would help those rebels...
I flashed the new Sprint 61085 prl over from the stock 61007 Boost prl and immediately noticed HUGE speed differences. Thank you aenoch. Your instructions and links to the tools worked flawlessly!
Where did you find that PRL? THe list i have doesn't show that one listed....can you link the source of PRL files please that you have been using?
I'm just going to throw this out there. I havn't done any regular testing however I have found that the time of day makes a HUGE difference in speed as well. for me I've gone from .15Mbps @ 12:43PM to 1.9Mbps & 131ms (peak) @ 4:50AM that's with stock boost PRL. I'm going to manually update to the 60687 and see how that compares.. Probably won't get another early morning test in because I'm usually asleep at this hour. Ok so I just updated the PRL its now 5:16am and I have reached 2.01mps thats pretty consistent too. that 1.9 from before seemed like a freak accident. The new network graph has a much more stable look / average to it. There is a definate improvement. Very curious to see how this performs in the afternoon. Thanks for the how to aenoch!
..... any one know how to get an LG LGL55C Optimus Q into diag mode? cant seem to find it any where and the dial code listed here does not work
Works great on the LG Marquee. Didn't even need use the hidden menu when changing prl. Just plug the phone in, set COM port, enter msl in spc box, click the spc blue button and BAM! It picked up my phone and I proceeded to change the prl. Worked like a charm.:thumbup:
Cheers aenoch. Thanks for the TUT. ;)
Special thanks go out to lMonsterl for taking the time to share his wisdom with me and give some pointers. Thx Bro :D
@aenoch Do you mind if I use some of this info to make a tut for people in the Prevail forums? Ill give you all the credit for your work, I just need to change a few things for it to work for the Prevail. Thanks:)
